  • 6
  • 7
  • 8
  • 9
  • 10
By johncondor
#1663584
"Johncondor , Any New Year pressies to share ?"
Following MichaelP's helpful story of the failed elevator gap seal we decided to try fitting a temporary seal. As the gap between the elevator and tail plane is only about an eighth of an inch we did not really expect much effect. How wrong we were. It has transformed the trim handling beyond our wildest dreams and removed a long standing problem.
Next job- to do it properly and remove the fixed trim tab that someone fitted in the dim and distant past.
pilotbarry, kanga, Paul_Sengupta and 3 others liked this
By condor17
#1663627
Jc , Brilliant news .
Also great is the power of the 'pooter ..... and thanks to this forum . Tab may have been put on B4 this age of sharing information and ideas .
rgds condor .
mick w liked this
By mikehallam
#1663667
This is one excellent exchange - which adult style occurs in spots between other nonsense subjects !
Off subject :- If MichaelP recalls the Redhill Strut and his fleet of a/c ca. 1970's perhaps he'd kindly contact me ?
mikehallam, Jackrell's Farm Airfield
By Andrew b
#1677424
Hi all in using this thread to ask if anyone knows what happend to the remains of condor g ayfg which was damaged beyond repair in2011 I believe. I just wondered if there are any spares around still if anyone has any imfo can they let me know pls
Cheers Andrew
By Genghis the Engineer
#1678978
By the way, any Condor owners.
When we had ours, some eejit whose name may well have begun with G managed to taxi over the fuel cap / gauge combo, wrecking it. As a result, I designed and had made a new one - I have a box with the bits and drawings to build at least one more, now of no use since I no longer have a Condor.
Any use to anybody?
By Andrew b
#1679045
If it's the cap rod and float type I would be intrested .mine still works but a spare to play around with would be good if it's going spare pls pm me
Cheers Andrew
  • 6
  • 7
  • 8
  • 9
  • 10
