Tue May 18, 2004 10:24 am
#82137
Vince: An MOR would have been an appropriate step. FWIW Generally, I would avoid heated verbal exchanges if you subsequently intend to make a formal complaint.
Pilots will contact the FISO and request taxi instructions. This is a requirement under Rule 39. The FISO will issue taxi instructions and information to assist pilots in preventing collisions between aircraft and vehicles and obstructions on the manoeuvring area or between aircraft moving on the apron. Instructions to aircraft on the ground are issued up to the holding point of the runway to be used for departure. FISOs cannot remove the permission granted by the aerodrome authority, or give any instructions, of their own volition, beyond the holding point for departing aircraft.
ginj wrote:I agree with Vince, a polite word in the ear
pa28-150 wrote: Also the salaries saved should mean cheaper landing fees (or at least no further increases)!!!!
pa28-150 wrote:Doesn't all this prove the point form an earlier discussion - that they should all be unmanned!!! Just make your call and get on with enjoying your flying.
pa28-150 wrote:Doesn't all this prove the point form an earlier discussion - that they should all be unmanned!!! Just make your call and get on with enjoying your flying. Also the salaries saved should mean cheaper landing fees (or at least no further increases)!!!!
