By G-BLEW
#846443
I will probably need to replace my C182's alternator (again) in the near future - does anyone have any experience of the available brands?
Thanks
Ian
By Colin G
#846448
Why replace when it can be overhauled?
If you are wanting to replace it, then Plane Power Alternators appear to be an improvement over the stock alternator.
Adams Aviation are the UK suppliers of Plane Power.
By G-BLEW
#846472
This is my second alternator in less than three years, last time the casing came apart! I am trying to discuss the fault with the US manufacturer, but so far it is a one way conversation.
Ian
PS I should add that Adams supplied the alternator (it isn't a Plane Power model), sorted it out the problem last time without delay, and have offered to get it sorted this time. I may still take them up on their offer, but would like to discuss the issue with the manufacturer first.
By Aerotech Flyer
#846479
It's all the arrays of new equipment that you keep testing for the magazine. The alternator can cope with having 4 handheld GPS boxes all running off a 4 way adapter plugged into the cigarette lighter, but it's the cappuccino maker that's drawing the excess load that's finally dragging it down! :wink:
AF
By SteveC
#846533
What make of alternator? I had exactly the same problem in IMC climbing out of Guernsey . Low voltage light came on and I returned. The alternator had literally come apart and fallen off the back of the engine and it was a new one to replace one that failed a couple of months earlier when climbing out of Dinard.
Ian
By G-BLEW
#846537
Kelly
Ian
By SteveC
#846540
Kelly
Ian
Yep, same one. I thought it was one of those million to one events. Apparently not.
By letsgo
#846566
Similar experience to me, 2nd Kelly Aerospace Alternator failed at 18 months and around 60 hours. Just to make it worse the 2nd voltage regulator also failed at a similar number of hours.
By mlawton
#846580
Put a new Kelly Voltage Reg on my 172 two weeks ago, It lasted just 6hrs!! Then died!
By Cub
#846628
Is this relevant?
By Leighton CZ
#846714
Seems to me there is problem with the design of the replacement OR you have a serious balance /mis-alignment / mounting problem causing excess vibration.
Having had a lot of experience with auto-alternators. GA alternators a little different. The main problems used to be Brushes wearing out- occasionally the odd diode would go open circuit which lowers the voltage output, regulators going duff - no output at all. Very rarely, a bearing would be noisy - but still running ok.
The alternator on my Pup is a Delco Remy (General Motors) with a remote mounted regulator, I have only had the brushes replaced once in 14 years and had to have a mounting hole rebushed. I bought a new regulator (£230.00) for it a year ago as I had problems with the Low Voltage light coming on very intermittantly - Turned out to be a momentary overload causing the Field Breaker to trip when flaps were being lowered with everything else on.
#846807
Leighton CZ wrote:Turned out to be a momentary overload causing the Field Breaker to trip when flaps were being lowered with everything else on.
Probably a problem with the earthing/ground connection.
By Cub
#847042
This is what I thought I had posted?
By G-BLEW
#847275
Yes everything to do with that - here's part of an email that I received today from Tim Gauntt, Kelly's Director of Warranty and Tech Support
The looseness of the case is a mechanical issue on all the Ford style alternators. The way the housings are fitted to the stator allows for movement after the alternator is heated up and run with a load, something which we cannot duplicate in production testing. This is why you found the housing bolts loose but still safety wired. We currently affix a decal to the housing and recommend the through bolts be re-torqued after the 1st 10 hours of operation and then each 100 hours thereafter. It’s been my experience the 1st 10 hour re-torque and the 1st 100 hour inspection will be all that’s needed.
Here's a picture, sent to me by John Miller, a South African editor. It shows what happens if the bolts aren't torqued.
So if you have a Ford style alternator, make sure that you get the torque of the bolts checked as per Kelly's suggestions
