KevinH wrote:mikej wrote:The Seneca is at 1,999lbs to avoid Eurocontrol charges. I'd be curious to know what the Seneca "weighs in" at in the US
The new ones on the US web site are 2165KG.
Yes well done.
Scud
mikej wrote:Don't most Warrior II in the UK have a MOTW of 2325lbs, but the same have a MTOW of 2440lbs in the US.. the difference being the cost the CAA want to amend the POH in the UK? purely a paperwork exercise I belileve.
Ergo... is it unsafe in the UK to fly a warrior II at 2400lbs in the UK?
KevinH wrote:Moli wrote:Kevin
Ah.... okay it was a genuine question to which I knew there would be a legitimate answer or you wouldnt have posted what you did, although I didnt want to assume you and FF were refering to the same thing .
My original point though is not referring to legally approved ferry pilot ops but to run of the mill GA & how / why do some people appear to operate aircraft significantly overwieight.
Moli
I don't know that many people do operate significantly overweight, I certainly don't, but I do think people regularly may be a bit over. If an aircraft can be legally flown 25% overweight then this isn't because the ferry pilot has magical powers, it is that the aircraft will stand it. Flying 25% over must be really horrible and not something you want to make a habit of, but 3% makes virtually no difference although that doesn't mean I would do it unthinkingly.
Curry????
mikej wrote:Curry????
Just occassionally you have a good idea Scud! yes please!
quote]
http://forums.flyer.co.uk/viewtopic.php?t=27048&start=15mikej wrote:what I'd like to know.. is has there been an impact in people decision to use/buy and Aztec because of this.
mikej wrote:In answer to your question.. I assume the figure was derived, by some geezer saying "What's the max weight we can have without incurring Eurocontrol charges" and then writing it on a bit of paper!!
