Fri May 27, 2022 10:24 am
#1912789
MichaelP
Wandering the World
Wandering the World
Irv Lee wrote:Leave it! 03 is downhill... Why destroy the poor (wo)man's ILS to the thrrshold? You line the tip up with the rough just before the runway, if the tip moves up the runway you need more power, if moves to.tbe 26 taxiway you need less power. At the moment you know you cannot hit the tree you convert to a glide approach, usually by lower the nose to drop into the pocket behind the wood, start to flair over previously mentioned rough, touch down in first 20 metres of 03
Sooty25 wrote:what would happen, if you clipped the tree, and ended up dumping your aeroplane on the road? (apart from a mess)
Who would be liable, the tree owner for allowing it to obstruct an airfield approach?
johnm wrote:Those trees look ready for harvesting........
Shoestring Flyer wrote:A few minutes with a chain saw looks to me like it would sort the problem.
Someone at Popham needs to do a bit of polite begging/persuading and asking of the owner of the said tree if this can be done.
