marioair wrote:what about IMC
I am not sure what you mean by IMC? clouds are the same in Paris as London, you have passed few MET exam, so you know how they look like
If you are referring to aerodromes minima, then don’t go to StCyr & Lognes in IMC it’s illegal, it’s VFR only with proper VFR ATC with legally binding runway weather minima, they also require personalised weather briefing by phone if you intend to operate on Z/Y-FPL over there (see page 20 of French GEN3.5 for phone numbers)
All other airports are IFR, you can file I-FPL for the majority of airports in France (except those in page 20 of GEN3.5, Courcheval & Lognes, StCyr basically), in Golf, you can depart/land if you are happy with weather as long as you maintain 1.5km visibility then you can change flight rules as you wish in Golf but be careful to stay out of Echo airspace it’s everywhere above FL65 and not shown on the map (you need clearance to swap VFR to IFR in Echo), you also need radio contact with FIS and active flight plan for IFR above 3kft, obviously if you intend to fly in airspace you need both slot
and clearance “to join”, voila !
At Pontoise you can depart with 400m without ATS (it’s written in your Jepps/AIP for takeoff minima without ATS) just get your startup IFR clearance by phone, if you are landing IFR without ATS in the tower, you need to give landing ETA to approach controller and raise your minima as you are supposed to fly visual circuit following the instrument procedures without ATC/AFIS, then call ATC to close your IFR flight plan after you have landed
