Mon Dec 27, 2021 2:02 pm
#1890430
rdfb wrote:For example, the "battery low" alert will be accurate (instead of getting 30 seconds warning as you might with rechargeables when the electronics is designed to predict remaining battery life using the alkaline discharge curve), you'll get the advertised battery life, and when any battery runs low the equipment will start to malfunction (requiring a reset).
As I understand it, that's the main reason for avoiding rechargeables - nothing to do with causing damage. With an alkaline (where voltage degrades slowly), the 'low battery' warning will give you plenty time to do something about it. With a rechargeable (voltage drops off a cliff when it runs out), you might not even get a warning before it shuts off. As with most inconveniences in aviation, that's guaranteed to be at the least opportune moment!
Rob P liked this
