Wed Nov 24, 2021 1:14 am
#1884330
I thought the first aviation law change in Jan 2021 was to let 5700kg pmd and FCL licences be used in part 21 aircraft with no stipulation on flight rules and therefore could be used by ir-r holders.
Then they removed the ability to declare the 2000kg pmd at all.
After an outcry, they brought a later exemption allowing 2000kg pmd use too and restored the ability to declare one alongside the 5700kg limit - but for such use of the lower mass limit, there were more restrictions, like vfr,
Now the caa webpage on pmd use says fcl licences are restricted to making the 2000kg level of pmd - ie can only HAVE the lower level
https://www.caa.co.uk/general-aviation/ ... te-pilots/
Notice the "only" in that final paragraph of the quote
Licences issued in accordance with the retained UK Part-FCL as amended by Aviation Safety (EU Exit) Amendment (SI 2021/10):
UK Part-FCL PPL to fly UK (G) registered Part 21 and non-Part 21 aircraft.
UK Part-FCL LAPL to fly UK (G) registered Part 21 and non-Part 21 aircraft.
Valid for flying with the following operational conditions:
Holders of a UK Part-FCL PPL or LAPL licence can only make a pilot medical declaration to the at or less than 2000kg MTOM criteria as they are limited to the privileges of the LAPL.
Irv Lee - (R/T & Flight Examiner)
Deconfusion & Preflight Aide-Memoire: http://tinyurl.com/pilotpal
UK GA Twittering not Tw@ering: @irvleeuk
