Tue Nov 23, 2021 11:38 am
#1884223
lobstaboy wrote:But too many folk just don't do that, do they? They just bang it in SD or other software and go.
I think you would be more likely to register a gliding site or drop zone by using SD rather than a cluttered chart. SD lists everything en-route that is a hazard to your journey - including glider and paradrop sites. I have more than once had SD pick up on a hazard proximity I had not noted while planning the route...
I have no idea what the pilot in question driving the cirrus used for flight planning, though the straightness of track indicates GPS-linked autopilot use. I wonder if a panel GPS was used and what kind of database it had - ie. if it wasnt an IFR setup that was abnormally being used VFR...
Tim Dawson, ls8pilot liked this
Its generally best to make a hole in the sky.......not the ground...
