Sun Oct 10, 2021 11:47 am
#1875724
Cub wrote:Perhaps we could turn the debate on its head? How can you be ‘controlled’ within the ATZ inside Class G. Your contracted obligations under U.K. FIS when operating inside an ATZ in Class G are exactly the same as outside of the ATZ.
ICAO allow Aerdromes surface/circuit/departure/arrival in Golf to be controlled without controlled airspace, you do receive Air Traffic Control Service
SERA also allow traffic to be controlled in “Aerdromes vicinity” in Golf without controlled airspace
Nothing UK specific really, say France, both StCyr and Toussus are in Golf and are controlled in ground, circuit and approach/arrival (also Lognes, Chavenay but they have RMZ), Toussus is even IFR and their ATC controls the SID/STAR that goes as far as 50nm away including the bits in Golf but outside these and CAS you just receive information
I am not sure about mechanism in UK ANO? my impression it’s ATC ATZ but I could be wrong…
There is a line to be drawn somewhere between receiving FIS away from aerodrome and receiving ATC in short final or circuit, there is no exact definition, if it’s not the ATZ boundary then what it is? maybe it’s 30nm away at IAF for IFR? but my bet for VFR unless there is an exception it’s ATZ (Redhill & Biggin has an exception from ANO as their ATC controls VFR on few VRP outside their ATZ)
I recall once flying ILS at Exeter when unknown traffic pop-up just as I started the descent, ATC passed info rather than requesting go-around, I just acknowledged, so maybe it’s the case of YMMV? they can’t clear you to land though without empty runway but you have to be in ATZ to get that…
