Tue Sep 14, 2021 8:44 am
#1870220
Isn’t this really significant news? Very exciting
PPL(A) SEP, MEP, SE/IR, IR(R), Night
which can be received via ADS-B 978 MHz receivers, including CAP1391 devices
johnm wrote:If I've understood correctly with my SE2 I can have either TIS_B or FLARM but not both, so TIS-B which includes FLARM ought to be configurable?? In the meantime that may be why Lasham was not interesting the other day......
shortwing wrote:As i'll be going down that way, will my SE2 pick this up and are any settings required to make it work?
Cessna571 wrote:PAW/SE2 will both work.
Everyone can keep their PAW until they upgrade it.
(I’m presuming PAW can pick up TIS-B, I think it can)
Paul_Sengupta wrote:Cessna571 wrote:PAW/SE2 will both work.
Sort of. It was programmed into it some while back, but to receive 978 you'll need another DVB dongle (and either an antenna splitter or another antenna).
Cub wrote:Before everyone gets too excited, it’s probably worth pointing out that you require a UAT device to receive TIS-B and FIS-B.
flyinfox wrote:Cub wrote:Before everyone gets too excited, it’s probably worth pointing out that you require a UAT device to receive TIS-B and FIS-B.
It will require a network of ground stations as well wont it?
