Tue Jul 20, 2021 6:31 pm
#1860061
Hi All
Cardiff has started requesting that flight plans are always filed for all VFR flights outbound and inbound.
I use Skydemon so sending a plan is no issue, but I would appreciate some help on understanding how you activate / open a SD flight plan when departing smaller fields with only A/G radio services or even no ground services?
Is it simply a case of submitting the SD flight plan, and then asking London FIS to activate the plan once departed? Or is there another / better way, as often London FIS are really busy.
Many thanks
Many thanks
