Sun May 16, 2021 6:56 pm
#1847323
TopCat wrote:Lockhaven wrote:Reaching critical AoA at low speed you will probably have a large stick/yoke deflection.
Agreed.Reaching critical AoA at high speed you may well have a very different stick/yoke deflection.
Can you elaborate?
I haven't looked carefully, but if I let the speed decay towards the stall, at say 78 knots (ie 55 x 1.41) in a 60 degree banked turn, I'm pulling quite hard, and the yoke is quite a long way out.
I'll try and remember to try it and look next time I fly.
G load on turns or G load wings level on bottom of loop scramble it but yes it still a long way of control travel, most likely aircract will never stall with stick/yoke locked on neutral pitch travel (not in let go unless it's trimed there)
