By Oldfart
#1845560
Passing through Glos yesterday I taxied out behind a blue Pitts Special, which from the prop speed and large exhausts, was fitted with a Turbine engine.
From the Fire Appliance in attendance and RT ,chat it was obviously a first flight.
Info??
By plus7g
#1845568
Thought for a minute someone had a Pitts Toucan over here in the UK !!! - I believe their downfall was the mass of air needed for the PT6 which wasnt available during most advanced aerobatic manouvres (sp?) - impressive aircraft ( the Toucan) though....... :D :D :D :D
By Iceman
#1845572
I remember a couple of jet-assisted aircraft at Oshkosh 2019. The first was a Pitts type of aircraft which an extra jet engine for good measure. The second was a ‘Yak 110’ which, not content with already having two piston engines, added a jet engine for a bit more fun. Both provided good ‘beat up’ displays with a lot of noise :thumright:.
Iceman 8)
By Iceman
#1845578
That was the ‘Pitts type’ of aircraft to which I was referring (I never claimed to be good at aircraft type recognition).
Iceman 8)
By Rob L
#1845608
russp wrote:https://www.richgoodwinairshows.com/jet-pitts this? - I think they are 'actual' jet engines not a turbine though.
It appears @russp is correct. This particular Pitts is a piston-engined Pitts with the addition of two small turbojets. Easily mistaken by the OP as exhausts for a turboprop.
By Kemble Pitts
#1845648
Now this is quite interesting, the OP called it a turbine, which is correct. He didn't call it a turbo-prop, but people seem to be suggesting he did; why?
By russp
#1845784
Because he arrived at the 'Turbine' conclusion from the prop speed and large exhausts.. at least that was my line of thinking.
By Rob L
#1845791
Large "apparent" exhausts...an easy misunderstanding, especially if seeing strange appendages upon a un-normal-looking aircraft (and concentrating upon the management of one's own aircraft during taxying) :D
By Sharpshotg
#1845920
Hi Old Fart, I have a feeling you are from Brimpton.
The Youtube link will hopefully answer some questions about The Anana sponsored Pitts Special that you heard at Glos on Thursday :D
