Tue Apr 20, 2021 1:56 pm
#1841650
Afternoon All,
I'm looking at buying an aircraft powered by a VW 1834cc engine with Leburg ignition which has no starter motor. I had a go at hand-propping it to get it started, however I couldn't (safely!) get enough force into the throw to get it past the compression point (for want of the correct term!). What kept happening was that I would position the blade at the 2 o'clock position and swing from there, however when the blade got to the compression point (between 6-7 o'clock) the blade would simply bounce back to around the 5 o'clock position.
I'm not the most confident of hand-proppers however I had no issue getting the C90-powered Cub I used to own a share in started via hand-propping. My prospective co-owner also had a go and he couldn't manage it either. Part of the issue was that the prop blades were quite narrow, so it was difficult to get purchase on it without wrapping fingers around the trailing edge. Another factor that could affect it is that the engine hadn't been run in a while and only had <20 hours since overhaul.
Can anyone with experience hand-propping VW engines provide some insight as to whether they are normally this difficult to start??
TIA,
Adrian
TIA,
Adrian
