oldbiggincfi wrote:Can I ask DAVE W to reproduce that rather splendid chart .
I fear some of our A/C group members have lost the plot and need reminding .
Thanks in advance .
I think it may be 'in update'
.I'm pretty sure someone in it will know if aircraft is a part 21 or not, and know syndicate rules for flying after a break.
basic rule #1: UK licence: does licence number have FCL in the licence reference (number)? if so, you're lucky. If not,
if it is a Part 21 aircraft, have a look at the final item of page 2 of
http://www.higherplane.co.uk/bfr-ground.pdf and fly the aircraft with that in mind.
As for licences/ratings:
If rating has expired, tough, have a proficiency check with an examiner, there was no extension of ratings or medicals into 2021 whatever your barista told you.
If no rating because you have a LAPL(A), have you got 12 to&l and 12 hours of either p1 or pu/t in a suitable aircraft, of which a minimum 60 minutes is pu/t training, in the 24 months before the intended flight? (Any p1 could be fixed wing microlight if you have differences training signed off.) If yes, fly, if not, make up the '12s' dual or have a prof check with an examiner. If you do the former, and fly p1 on a different day, check again. If the latter, no worries for 2 years (except 90 day passenger rule)
Irv Lee - (R/T & Flight Examiner)
Deconfusion & Preflight Aide-Memoire:
http://tinyurl.com/pilotpalUK GA Twittering not Tw@ering: @irvleeuk
