Fri Jan 15, 2021 12:09 pm
#1820285
We completed a permanent installation of Rosetta Pilotaware earlier in 2020 including connection to our Funke TRT800A Mode S ES transponder with latest firmware (5.3). Carried out by professional avionics engineer who confirmed ground tests and that ADSB working correctly, set to SIL=0 as non certified GPS from Pilotaware. Sent off the relevant mod forms to LAA last year. Just (January 2021) had the following response from LAA saying that they won't approve the connection for ADSB out because the "TRT range does not comply with the ETSO standard". I have seen nothing on this anywhere, with CAA /LAA and everyone else including Pilotaware encouraging installations of EC units and in particular connections to ES capable transponders for ADSB out as a preferred minimum. Advice?
LAA response to modification forms sent in:
Unfortunately, we can’t approve any ADBS-out connection for the Funke TRT series transponders as they do not possess the appropriate approval. The TRT Series is not approved to ETSO Standard C166B, therefore the ADSB out function can not be approved for use until this certification is sought by the manufacturer. The TRT series is sold as “ADSB Ready” but does not necessarily meet the minimum performance requirements of the ETSO. Unfortunately all transmitting avionics installed in LAA aircraft must hold the relevant approval from the CAA, EASA or FAA.
I am sorry this is not the news you wanted to receive. However, you may still use the pilot aware device in your aircraft as standalone electronic conspicuity not connected to that transponder. If you permanently install it you will just need a PMR in your airframe logbook from your inspector.
If this is correct, it throws into serious question why we are being encouraged by all and sundry to spend money on fitting devices which the regulators won't approve. I am struggling to see how this can be right, especially as I have seen nothing on this subject (LAA approval declined) for this elsewhere.
Anyone else had approval refused by LAA for Funke-GPS ADSB connection?
