#1815968
Stampe wrote:“I (and many other local pilots) cannot risk infringement action so avoid the airspace when ATC is closed.”
That sadly sums up the febrile atmosphere created by current incumbents of the dreadful CAA.
Chevron the CAA actively withhold any evidence that might aid an alleged infringers defence.This is a well established fact and a major reason that trust between the GA and ATC communities has broken down! Stampe
You have every right to see a transcript of the RTF for the time of the alleged incident - sure they won't let you listen to the tape itself, that is kept at the airfield but the CAA go to the airfield and transcribe the RTF for incidents of any sort.
#1815975
An excellent suggestion rdfb and a form that I have used in the past.It is of course dependant on the fact that this form is ever even looked at.Many suspect it is just a frustration venter for GA pilots.Sadly it appears no one is batting for GA in this country in the “establishment”.
#1816006
AlanM wrote:Just a thought:
@G-BLEW - has anyone approached the Manager of ATS at Cardiff? It may be easier to find out what the actual, unit specific issue and policy is.
Yes, I have had comms from someone who has done just that. Will ask if I can post the result here. I have yet to get a reply from the CAA, but will chase that and Cardiff after Christmas.
Ian
MikeB, AlanM, Stampe and 1 others liked this
#1816014
Ian
Strong work! :thumleft:
I am interested for lots of reasons.
#1816100
Stampe wrote:An excellent suggestion rdfb and a form that I have used in the past.It is of course dependant on the fact that this form is ever even looked at.Many suspect it is just a frustration venter for GA pilots.Sadly it appears no one is batting for GA in this country in the “establishment”.
If it turns out that the form is never looked at, what we should do is arrange for a representative organisation to fill in the form on behalf of pilots, take a copy, and compile statistics on the copies. Then we'd end up with the stats, too, and that information could be used to justify seeking further action.
#1816136
One of the noble Lords asked a minister how many FCS1522 where received by the CAA in 2019. There have been 7 in 12 months. So read or not read easily discussed away as insignificant by regulator and ANSP. (Except if all at the same ansp in the same trimester )
AlanM liked this
