By Lefty
#1803372
Any know what the blockade of parachute jump site NOTAM’s is across the entire gap from south of Lasham to Frensham ponds ?
By ls8pilot
#1803375
Lefty wrote:Any know what the blockade of parachute jump site NOTAM’s is across the entire gap from south of Lasham to Frensham ponds ?
Reading the detail there are not PJE drops, it's Paraglider sites. Not clear if these are ridge sites or whether they are winching.
Time there was a new class for Paraglider sites I think - the hazard is very different between a gaggle of Paragliders in a thermal or ridge flying vs a group of free-fall parachutists plummeting earthwards at 120kt!
#1803411
Pete L wrote:Which electronic conspicuity solution do paragliders carry?
An orange flare to each ankle.....................
By Boxkite
#1803471
Check the contact phone numbers in the NOTAMs, you might find they are all the same, meaning they are hedging their bets as to which site (wind/lift) will be the best on the day and they'll leave all the unused sites' NOTAMs as active.....
(That said, I don't see any NOTAMs in that area.)
By TLRippon
#1803711
Paragliders also carry out cross country flights, some with quite impressive range. Our local Notam yesterday was centred on Rutland water but the largest collection of them was over The far side of Leicester.
By TheFarmer
#1803750
They’re anticipating a series of Cirrus pilots panicking all at the same time. :D
Iceman, Danny, skydriller and 4 others liked this
By GAFlyer4Fun
#1803780
IIRC these Notams were for the one day upto 5pm (utc) up to 2800 ft.
If one person organised the whole lot then someone needs to remind them it is one of the few north/south transit areas between southern England CAS so lining them across the gap is perhaps not the most considerate thing to do for other airspace users.
B1engineer liked this
By GAFlyer4Fun
#1803781
Stall practice? PFLs?
:wink:
By low&slow
#1803813
GAFlyer4Fun wrote:If one person organised the whole lot then someone needs to remind them it is one of the few north/south transit areas between southern England CAS so lining them across the gap is perhaps not the most considerate thing to do for other airspace users.
They're not blocking anyone's path. They are as entitled to use the airspace as any other aviator.
By Duncan M
#1803835
Notam, or Notice to Airmen, are indeed just information provided for users of that airspace. They do not prevent other users but merely inform of a particular event/timing.
Problem arises when a significant portion of busy airspace is Notamed and then not used, pilots that have given it a wide berth will not bother next time the same Notam is issued. If the notamed airspace is not being used then notam should be cancelled.
I fly in the area of one of these recent Notams regarding paragliders and did not seen one over the past two days.
