By TheFarmer
#1803274
Does anyone have a suggestion for keeping the engine bay warm overnight?
Many of my flights are at dawn and the cooler temperatures now mean my 912S is taking ages to warm up. Rather than waiting for 10 minutes (+) starting from ambient temperature, I’m convinced that a 20 degree head-start with some kind of overnight heater will easily halve the time.
I could just put it in the engine bay and turn it on the night before I fly.
Does anyone use one of these?
https://www.demon-tweeks.com/uk/wolveri ... er-727157/
Interested in comments or suggestions.
By Shoestring Flyer
#1803277
To help warming up on a Rotax 912 for winter months:-
Is an oil thermostat fitted?
Have you got the coolant radiator partially blanked?
Also Oil cooler partially blanked?
Both will speed up engine warm up.
Takes a bit of experimentation to get right amount blanked off but then should warm up as fast as in summer.
By TheFarmer
#1803320
Oi!
I’m quite up to date actually, I’ll have you know. I’ve got power steering on my Land Rover and everything. :D
Rob P liked this
By Shoestring Flyer
#1803325
TheFarmer wrote:Oil radiator is partially blanked so that the in-flight vanes create 90 degrees in flight when half open.
No oil thermostat (I dont think).
Maybe something this simple wood help?
https://www.toolstation.com/dimplex-the ... gJWsfD_BwE
You definitely need a proper Oil thermostat for a Rotax fitted in the line between the oil pump and tank. Makes a big difference.
Talk to either CFS ( Rotax dealer) or Eccleston ( sub dealer). My choice would be Eccleston as thay are more user friendly.
https://ecclestonaviation.co.uk/?v=79cba1185463
Pete L liked this
By bilko2
#1803337
I made this to keep my O360 dry in the winter. Fan and about 40W of resistors blows warm air into air intake and flexi tube recirculates from other air intake.
By nallen
#1803342
TheFarmer wrote:Many of my flights are at dawn and the cooler temperatures now mean my 912S is taking ages to warm up. Rather than waiting for 10 minutes (+) starting from ambient temperature, I’m convinced that a 20 degree head-start with some kind of overnight heater will easily halve the time.
You mean you don't have your butler start it up and have it ready for you? :D
#1803357
£20 would get you an electric blanket, designed for humans. Wrap it round, shove it on a time clock... (no mains electricity in my hanger so i can only dream...)
By Bill McCarthy
#1803361
Your own first idea was the best. Scrub round anything “home made” as you may have a tough time explaining to the insurance company about the pile of ashes that was your aircraft and hangar.
Shoestring Flyer, Dodo liked this
