Page 2 of 2
Re: G5 power down?
PostPosted:Mon Aug 17, 2020 8:23 am
by NDB_hold
But what about 50 year old aeroplanes?
Re: G5 power down?
PostPosted:Mon Aug 17, 2020 8:57 am
by Dave W
Thanks, all - that's helpful.
@User72, just checking: Did you mean DO-160? In which case I should know that.
Re: G5 power down?
PostPosted:Mon Aug 17, 2020 10:59 am
by User72
Yes, DO-160 is the environmental spec for airborne eqpt,
https://en.wikipedia.org/wiki/DO-16050 year old aircraft now have modern batteries and starters, as well as modern equipment. If they do still have 50 year old Cessna avionics then by all means switch them off at start up (if they still work).
Re: G5 power down?
PostPosted:Wed Oct 14, 2020 6:43 pm
by ianpaullogan
My G5 switched itself off in flight , no idea why. When back on the ground it powered up again after holding the Power switch for 30 secs.
Anyone else had this ?
Re: G5 power down?
PostPosted:Wed Oct 14, 2020 6:47 pm
by GrahamB
ianpaullogan wrote:My G5 switched itself off in flight , no idea why. When back on the ground it powered up again after holding the Power switch for 30 secs.
Is it on the latest software version?
Anecdotally it was a problem with an earlier version that was subsequently fixed.
Re: G5 power down?
PostPosted:Thu Oct 15, 2020 7:35 am
by TLRippon
If you keep your finger on the button for 19 seconds in the air it should turn back on.
Not had anything like this happen with mine fitted in November last year.
Re: G5 power down?
PostPosted:Thu Oct 15, 2020 12:07 pm
by BoeingBoy
Well thanks Guys. I was about to ring my engineers and discuss twin G5's and an autopilot. With all the stories of inflight shutdowns I think I'll just stick to my six pack and keep renewing my vacuum drive shaft every six years as per the Tempest service bulletin.
Re: G5 power down?
PostPosted:Thu Oct 15, 2020 12:11 pm
by GrahamB
BoeingBoy wrote:Well thanks Guys. I was about to ring my engineers and discuss twin G5's and an autopilot. With all the stories of inflight shutdowns I think I'll just stick to my six pack and keep renewing my vacuum drive shaft every six years as per the Tempest service bulletin.
Two years now of using my (certified) ones and no shutdowns yet.
Re: G5 power down?
PostPosted:Thu Oct 15, 2020 12:15 pm
by Dave W
Another data point: 18 months here on an uncertified one, latest software standard, and again no shutdowns.
In fact, it's been seamless and very satisfied with it. We've done some long trips, too.
Re: G5 power down?
PostPosted:Fri Oct 16, 2020 1:09 pm
by riverrock
We've had ours installed since Feb - no shutdowns.
Re: G5 power down?
PostPosted:Sat Oct 17, 2020 12:45 pm
by PaulisHome
We've put two G5s and a GFC500 in the Mooney, to go with the GTN. Brilliant system.
Happy to discuss directly if you want.
Paul
