By User72
#1790979
Yes, DO-160 is the environmental spec for airborne eqpt,
https://en.wikipedia.org/wiki/DO-160
50 year old aircraft now have modern batteries and starters, as well as modern equipment. If they do still have 50 year old Cessna avionics then by all means switch them off at start up (if they still work).
By ianpaullogan
#1802969
My G5 switched itself off in flight , no idea why. When back on the ground it powered up again after holding the Power switch for 30 secs.
Anyone else had this ?
By GrahamB
#1802971
ianpaullogan wrote:My G5 switched itself off in flight , no idea why. When back on the ground it powered up again after holding the Power switch for 30 secs.
Is it on the latest software version?
Anecdotally it was a problem with an earlier version that was subsequently fixed.
By TLRippon
#1803053
If you keep your finger on the button for 19 seconds in the air it should turn back on.
Not had anything like this happen with mine fitted in November last year.
By BoeingBoy
#1803123
Well thanks Guys. I was about to ring my engineers and discuss twin G5's and an autopilot. With all the stories of inflight shutdowns I think I'll just stick to my six pack and keep renewing my vacuum drive shaft every six years as per the Tempest service bulletin.
By GrahamB
#1803124
BoeingBoy wrote:Well thanks Guys. I was about to ring my engineers and discuss twin G5's and an autopilot. With all the stories of inflight shutdowns I think I'll just stick to my six pack and keep renewing my vacuum drive shaft every six years as per the Tempest service bulletin.
Two years now of using my (certified) ones and no shutdowns yet.
By PaulisHome
#1803577
We've put two G5s and a GFC500 in the Mooney, to go with the GTN. Brilliant system.
Happy to discuss directly if you want.
Paul
