By Dave W
#1782487
It's got WiFi and is capable of showing traffic, so perhaps not impossible.
Unfortunately the manual (on page 1-46) has a broken link to a list of supported devices.
Edit: Here is the list, I think. uAvionix products are not on it in the 'Traffic' section, but it does say up front:
Avidyne wrote:The following list represents proven interfaces. There may be other devices that can be configured the same as one on the below list but Avidyne has not tested it and can therefore not make any compatibility claims.
Worth an experiment or two?
By Iceman
#1782488
The short answer is no as you need to go in to the IFD via a certified interface (ARINC / RS232). The IFD will not receive traffic / weather, etc., via WiFi / Bluetooth.
Iceman 8)
#1782490
Avidyne say you can't officially feed it with traffic from an unapproved device.
They also say they don't see why feeding it via RS232 from a PilotAware shouldn't work but I don't know anyone who's tried it.
Yet. ;-)
By leemoore1966
#1782492
Apparently GDL90 over RS232 at 38400 baud will do the trick
With software 10.2 to the IFD540, the 540 is compatible with the GDL-90 protocol, which means the IFD will display weather and traffic information from the NGT-9000. The wiring interface involves the RS-422 out connected to the RS-232 in at the IFD
Thx
Lee
By GAFlyer4Fun
#1782495
Original question was about SkyEcho providing the traffic.
The IFD100 App will display traffic from the SkyEcho. The IFD panel mount units will not.
If you want traffic on the actual IFD panel mount unit, the Avidyne website will say which units can provide the traffic without breaking the IFD certification. (No cheap options)
https://www.avidyne.com/product/ifd540-fms-gps-navigator/#tab-id-3
By neilmurg
#1782510
Paul_Sengupta wrote:Avidyne say you can't officially feed it with traffic from an unapproved device.
Yet. ;-)
leemoore1966 wrote:Apparently GDL90 over RS232 at 38400 baud will do the trick
Thx
Lee
I can lend you a PAw to try Steve!
Sir Morley Steven liked this
By PaulSS
#1782573
...........if that XXX/RS232 suggestion does work..................it will invalidate what was a certified IFD540 installation in a certified aircraft
What a sad and pathetic state of affairs. Something works and we can't use it because some genius has labelled another piece of tin as 'certified' :roll:
Sauvignon blanc in case you were wondering :D
By GAFlyer4Fun
#1782644
PaulSS this is nothing new.... the higher costs and regulation of anything in a certified aircraft is a much repeated forum comment over the years as to why some people prefer to fly LAA aircraft. :wink:
The IFD units are aimed at the IFR market so that and their high price tag probably means wont find many fitted to LAA aircraft types.
The 'genius' that comes up with anything new has to decide whether they are aiming at the certified or uncertified market. If aiming at the certified market, which is where the money will be in a worldwide market, they have to play by the certification rules of the FAA/EASA etc.
By PaulSS
#1782665
@GAFlyer4Fun Yes, I understand the system but just think sometimes they need to apply much more common sense, instead of just a black & white judgement. This is a classic case where a non-certified bit of kit (be it PAW or Stratux or whatever) can receive ADSB and could be piped to a certified display via RS232, thereby improving safety. I get the whole certified transmission thing but receiving just seems daft. A certified receiver doesn't do anything more and will use the same RS232 protocol, so it really is just jobs for the bureaucrats :(
@PeteSpencer
Not the famous N Z Sauvignon 'Cats Pee on a Gooseberry Bush' I hope?
I don't think it was that refined to be honest :D
Straight Level liked this
By Dave W
#1782679
@PaulSS, There's already a precedent with the connection of uncertified GPS to a transponder for ADS-B OUT in Certified aircraft under CS-STAN.
Perhaps that would be a route for those interested to explore?
Technology is outpacing the regulatory environment again.
Straight Level, PaulSS liked this
By GAFlyer4Fun
#1782690
Dave W wrote:Technology is outpacing the regulatory environment again.
It has been for decades. As technology becomes more advanced and sophisticated the certification gets more complex for all the advertised functionality and all the failure modes.
In the modern world of the general population wanting easy open connectivity for everything, the failure modes also extend from malfunction to misbehaviour and cyber attacks.
Only a matter of time before someone tries to hack/attack avionics remotely.
There will be those that think why would anyone want to do that? The same could be said for car systems where the designers either never considered it or decided nobody would want to do that,... until a few very public examples in the media several years ago.
With that in mind, does the aviation safety case really want an open door for plugging in any old uncertified thing into certified avionics? Whilst the overhead of certification can be a burden to progress, it is intended to provide some safeguarding for the pilot and passengers and the people on the ground below the flight path.
