Tue Aug 03, 2021 1:12 pm
#1862686
stevelup wrote:tripacer wrote:That's what I use, and even on a 4K display it gives usable performance: 15+ fps with fairly high quality settings. Not stellar for many games, but the picture out of the window doesn't change very fast at the speeds I fly.
Try turning the render scale down - this will keep all the UI and everything pin sharp at 4K but massively increase your framerate. If you knock it down to 70% you will pretty much double your framerate with almost no visual impact.
I can set the render scale down to about 70 and get 20fps. Below that the instruments start to get a bit furry at 4k.
