By James Chan
#1745950
The flight procedures at Redhill state that all users must have a serviceable alt-reporting transponder or words to that effect. Aircraft not equipped may be allowed subject to prior approval.
Does that mean a TMZ should be indicated on the chart where the ATZ is?
By xtophe
#1745985
Lerk wrote:No, because a TMZ requires Mode S doesn't it?
Not necessarly. The Farnborough ones require only A+C.
By pullup
#1745988
The requirement to enter the Stansted TMZ is a Mode S transponder if you do not wish to communicate with Essex Radar. No actual clearance is required.
If you are not equipped with Mode S then a positive clearance is required either from Essex Radar or Farnborough.
Is this not standard for any TMZ?
By ak7274
#1745991
Transponder Mandatory Zones require Mode S, meaning they do not have to contact anyone to enter.
Farnborough doesn't have a TMZ.
At least not accord to their AIP, my Paper chart and Sky Demon.
By pullup
#1745997
A mode S transponder is required to enter a TMZ. No radio call required.
If you do not have mode S then a clearance to enter the TMZ is required from the controlling authority.
By PaulB
#1746001
Which bit of the AIP is that in? (Just been looking but couldn't find it. SERA.6005 allows the ANSP to specify)
By xtophe
#1746002
Code: Select allFarnborough CTA 8 is a TMZ (Transponder Mandatory Zone). Carriage and operation of a transponder with Mode A code and Mode C altitude (or equivalent Mode S) is mandatory. Provisions for non-equipped aircraft are promulgated by the controlling authority 01252-526015 (ATC-Radar).
That's the wording in the AIP which will be valid from the 27th Feb in ENR2.1 for Farnborough cTA 8 and 9.
By PaulB
#1746014
I was meaning the more general bit that describes RMZs and TMZs.
By Tim Dawson
#1746016
Interesting you should pick up that wording about the TMZ for the new Farnborough airspace. Personally I think that is wrong. Mentioning that it “is a TMZ” in the remarks attached to the definition of a piece of controlled airspace most definitely does not make it a TMZ.
Someone has forgotten to actually define the TMZs anywhere.
By xtophe
#1746020
Tim Dawson wrote:Someone has forgotten to actually define the TMZs anywhere.
There are definition and requirement for mode S in GEN 1.5 para 5.3.
But the Farnborough CTAs are not listed there.
So either the Farnborough TMZ are non-existent as not properly defined
or
GEN1.5 is only for TMZ requiring mode S. The others are the default definition coming from SERA.
By Tim Dawson
#1746021
I think they are technically non existent as not properly defined.
That’s probably independent of any mode S question though, just an interesting aside.
By xtophe
#1746026
It seems there are also Holyhead CTA 15 and 16 which are defined as Class E + TMZ in ENR2.1 but are not in GEN1.5
Doncaster CTA13 also E+TMZ is in GEN1.5
In ENR2.1 all the notes about TMZ say "a transponder with Mode A code and Mode C altitude (or equivalent Mode S)" and so are at odds with GEN1.5
