With modern nav systems, when CAT and other IFR traffic is not now needing to go on constrained airways from waypoint to waypoint defined by fairly closely adjacent ground based beacons (Fan markers, Radio Ranges, NDBs, VORs...), it may well be the those IFR types whose operators may be wanting to 'cut corners' ..
That is true. Some ideas I've always liked to have:
- Introduce Free Route Airspace in most lower airspace by replacing most Class A/C/G ATS routes with Class E "everywhere" .
- Mandate ADS-B Out (or equivalent) around busier terminal areas and some busier regional airports.
- Reclassify most parts of the Manchester and London TMAs and surrounding CTAs to Class C, and add new higher altitude VFR+IFR transit routes.
- Compact existing Class D CTR's to make them look more similar to MATZ's joining a Class C, D or E CTA over the top.
- Add noise monitoring/restrictions from the "released" airspace to alleviate concerns of the local community.
- Airspace to be reviewed regularly depending on traffic flows. They go up an airspace class where needed, and down an airspace class when no longer needed.
If we don't take part in protecting GA access to infrastructure, the smaller aerodromes will be built over, the larger aerodromes will have exorbitant handling fees and awkward procedures, and airspace will be over-classified to Class A everywhere.
