buzzthetower wrote:Ok, interesting concept. So I assume that's a no then, I can't fly in as not a member.
It’s predominantly because space is limited. All the normal parking areas on the grass in front of the café and concrete hard standing at the rear are off limits to aircraft movements, being occupied by display aircraft and marquees (which are NOTAMed) (grass) and stalls/family rides/displays etc (concrete hard standing).
For the weekend, the grass area normally available to the north of the tarmac taxiway contains the fuel bowser, emergency vehicles and the mobile control caravan, used by the AGCS (Norwich SATCO, me and one other) and also the FCC will be positioned there, all of which reduces the grass area that would otherwise be available. Space also needs to be available to allow any of the display aircraft that require refuelling space to manoeuvre close to the fuel bowser. Whether post Shoreham airshow regs have any bearing on it too, I’m not in a position to comment.
Hope that helps...
Ian
