#1705210
Which ADS-B receivers work in the UK/Europe?
#1705214
For ground station use to display traffic on a screen, or for airborne traffic awareness use?
By T67M
#1705218
Almost all ADS-B receivers operate on 1090MHz (aka Mode S Extended Squitter), which is a worldwide standard. A small number only operate on 978MHz (aka UAT) which is only officially supported in the USA at this time as a solution to the frequency congestion problems on 1090MHz. The data format on both frequencies is ADS-B and is virtually identical, hence making a dual-band unit is (comparatively speaking) "easy".
It is a different situation when talking about transmitters, however, as a number of products are available for the US market which only transmit in 978MHz/UAT.
Edited to fix typo
gaznav liked this
By neilmurg
#1705225
T67M wrote:Almost all ADS-B receivers operate on 1090MHz (aka Mode S Extended Squitter), which is a worldwide standard. A small number only operate on 978MHz (aka UAT) which is only officially supported in the USA at this time as a solution to the frequency conversion problems on 1090MHz.
is I think: 'as a solution to the frequency congestion problems'
T67M liked this
#1705230
GrahamB wrote:For ground station use to display traffic on a screen, or for airborne traffic awareness use?
Stick in the aerial jalopy to work as a received to display traffic on SD.
#1705248
pete2052 wrote:PAW receives and displays adsb traffic on SD
Yup as does SkyEcho.
Interested in which alternative receive only options there are.
E.g. does this work?
https://flywithscout.com
or this:
https://www.amazon.com/dp/B07DVWH7BM
gaznav liked this
By Tim Dawson
#1705250
The popular ADS/B receivers in Europe are SkyEcho, PilotAware and PowerFlarm.
There are others such as iLevil and Stratux.
Scout/Sentry will not work with SkyDemon as they're Foreflight products, actually manufactured by uAvionix.
#1705258
Stratux does seem to offer a FLARM option as well.
Anyone experience with Stratux?
#1705265
We have a group member who has had a go with Stratux, not greatly impressed at this point, not sure why....
#1705268
Flyin'Dutch' wrote:Stratux does seem to offer a FLARM option as well.
Yes, it works well in the US where there's the 978 traffic rebroadcast.
It works here but is limited in that it only receives ADS-B (1090). If you don't care about the official case, you can put a single band one together for about £50. If you want the official case and want dual band then it's about £75, or more if you want the new low power receivers (though the new low power UAT receiver won't do Flarm, it's 978 only).
I have never tried the Flarm version, as I understand it, it's some sort of code overlay on top of an older version of the Stratux software. Not sure how happy Flarm would be for people to be decoding it for free in the air, and of course Flarm change their code every year or so, so it would then have to be re-hacked.
PilotAware is also based on a Raspberry Pi, does pretty much what the Stratux does and obviously also receives P3i, and the rebroadcast stuff in the UK. Nothing stopping you setting up rebroadcast stations across Europe though! ;-)
johnm wrote:We have a group member who has had a go with Stratux, not greatly impressed at this point, not sure why....
Possibly because there aren't that many puddle jumpers broadcasting ADS-B at the moment.
gaznav liked this
