#1693835
Looking at SkyDemon this morning there seems to be an airspace grab (Class D - 2,500' to FL65) from the Goodwood VOR (GWC) in to an extended area of Class D (Surface - 5,500') around Farnborough.
I wouldn't have noticed, but for the fact that when well zoomed out it looked as if so someone was doing rude tracks in the sky.....
#1693873
Whiskey Kilo Wanderer wrote:Looking at SkyDemon this morning there seems to be an airspace grab (Class D - 2,500' to FL65) from the Goodwood VOR (GWC) in to an extended area of Class D (Surface - 5,500') around Farnborough.
What is your definition of an airspace grab??
#1693918
Perfectly normal procedure iaw AIC Y101/2018 from 1230 to 1330.
Nothing sinister or unusual about it. I've never seen Skydemon but it's all adequately explained on the AIS published NOTAMs.
#1693926
On the AIS website:
Code: Select allQ) EGTT/QAECA/IV/NBO/E/025/065/5100N00047W014
B) FROM: 19/05/17 12:15C) TO: 19/05/17 13:05
E) CONTROLLED AIRSPACE (TEMPO) CLASS D ESTABLISHED IN ACCORDANCE WITH
AIC Y101/2018. CHART 3 DEPICTS THE AREA AS FLW, CTA (GWC TO ROVUS) WI
AREA BOUNDED BY A STRAIGHT LINE JOINING 510825N 0005034W (VCY
SLEAFORD) TO 511122N 0004159W (VCY ELSTEAD) TO 505209N 0003737W (VCY
SLINDON) THEN THE CLOCKWISE ARC OF A CIRCLE OF RADIUS 5NM CENTRED ON
505119N 0004525W FROM 505209N 0003737W (SLINDON) TO 505032N 0005311W
(VCY SOUTHBOURNE) THEN A STRAIGHT LINE JOINING 505032N 0005311W (VCY
SOUTHBOURNE) TO 511140N 0005805W (VCY GOLDEN POT) THEN THE
ANTICLOCKWISE ARC OF A CIRCLE OF RADIUS 8NM CENTRED ON
511612N 0004737W FROM 511140N 0005805W (VCY GOLDEN POT) TO 510825N
0005034W (VCY SLEAFORD) 2500FT AMSL/FL65 EXCLUDING LONDON TMA.
CONTROL AUTHORITIES FARNBOROUGH ATC/LONDON TERMINAL CONTROL.
2019-05-0398/AS4
Or on SkyDemon:
MikeB, znww5 liked this
#1693930
Tim's post above is a very good sales argument for his product. :thumleft: Official information is on a format from seventy years ago, Skydemon presents it a tiny bit more modern.
I've noticed similar temporary restricted areas on Skydemon before. Sure: I would have seen them on NOTAM but in a graphical form I immediately see if I'm affected or not.
#1693946
Something I might have blundered in to if I hadn't noticed it on SkyDemon.
So “airspace grab” means variously;
New CTRs at Southend/Norwich,
Exeter trying to join the airway with a CTR but also a well established, AIP promulgated temporal airspace for a short period.?
Gotcha. Jump on that bandwagon!!
#1693960
Indeed, anything that grabs the attention and hopefully prevents infringements...
Notams ?
Had one of our very own yesterday. I think I might frame it.
Selection of H. M. Bateman pictures on The Man Who.. . I'm sure there's one to suit our good friend Chevvron. http://www.hmbateman.com/gallery/the-man-who-.htm
