By Marvin
#1681055
riverrock wrote:
PaulB wrote:Sorry for the thick question... why do you need multilateration if the aircraft are transmitting their GPS location? How does this deal with altitude?
Curious, not critical before anyone assumes. This sounds quite exciting stuff.
I assume its to guard against a rogue entity / teenage geek from outputting false ADS-B position info.
Would also be useful to allow triangulation of Mode-S traffic which doesn't have ES to output its position, same reason that FR24 (etc) uses it.
The ground based MLAT Sites normally are actively transmitting, unlike the FR24, 360Radar services which are listen only. Therefore they can calculate location of SSR responses not just Mode-S and ADS-B and also exact the mode A/C response.
This Might Help although it's from a quick search of t'internet.
The Aberdeen announcement, not seen any other public announcement yet, is great step for the future of ADS-B and well done to NATS and CAA.
PaulB liked this
By CloudHound
#1681126
With the Airspace4All initiative at inter alia Barton I see a real risk of a joined up system sometime in the future :thumright:
Watching some Sun 'n Fun 2018 arrivals videos on UT, I was struck by the availability of traffic and weather data on one screen in many of the airplanes "braving" the lake arrival.
Our RV6 was up to day from Barton trying to get the TQ ADS-B gizmo to work. Sadly, some more menu setting needed but at least the ES function was on. One day, one day.
gaznav liked this
By kanga
#1681218
<old Cold Warrior :oops: > .. let's hope the BEARs, BACKFIREs and BLACKJACKs (and, conseqently, Typhoons) remember to switch on their ADS-B-Out :) </>
.. but, of course, we do still have enough Primary Radar with good enough low-level coverage, don't we ? :roll:
[Yes, well done, CAA/NATS. A joined-up system nationwide providing adequately-manned 'Radar' service requiring only affordable and small/light avionics on GA aircraft would be nice ..]
By gaznav
#1697789
kanga wrote:<old Cold Warrior :oops: > .. let's hope the BEARs, BACKFIREs and BLACKJACKs (and, conseqently, Typhoons) remember to switch on their ADS-B-Out :) </>
Why, they don’t have Mode 3/A or Mode S with Charlie either? That is one of the significant reasons for shepherding them around our airspace (and the fact that they may be up to no good!).
As for low level primary coverage then there has been some significant investment that many aren’t aware of. Here is a suitable news article: https://www.raf.mod.uk/news/articles/ra ... saxa-vord/
kanga liked this
By ls8pilot
#1697916
Dave Phillips wrote:
We’ve spent the last 8 months calibrating military WAM across the UK. This is a project being run by Aquila, a joint Thales/NATS enterprise,..........
Does this mean Brize will be able to see you if you are using ADSB only (no transponder)?
That would be good news!
By gaznav
#1697934
It should do but I don’t believe Brize have theirs yet. The only ones I am aware of are at RAFs Coningsby, Shawbury and Linton on Ouse. But I am out of the loop on the latest roll out plan. :-)
By T67M
#1697990
It will depend on the location of the receivers and the power of the transponder/ADS-B emitter.
WAM, as the name implies, is a Wide Area Multilateration system, so has relatively few receivers spaced quite widely. If your emitter is only in range of one or two WAM receivers, they will only be able to report the unverified position broadcast using ADS-B. If you're in range of three or (ideally) more WAM receivers, the position can be verified, and that is what is required (for example) to enter controlled airspace.
The situation is very similar with the various MLAT technologies (FR24, Radar360 etc) which have a much denser network of receivers, and we know that at low altitudes (e.g. below 2000ft) these can struggle to accurately determine the emitter's location despite having lots of receivers.
A low power ADS-B transmitter (e.g. SE2) could conceivably be in range of enough MLAT receivers to give a good position, but only hit one or two WAM receivers which would therefore be unable to verify its location. A high-power transponder-based ADS-B transmission in the same location could be detected and located using cheap WAM technology rather than expensive SSR, and this is why the CAA/NATS are pushing for transponder-based ADS-B.
By tomshep
#1697996
Why doesn't it surprise me that the most expensive solution is the chosen one? With the deregulation of airways coming, the whole FIR will become a TMZ and we little people can go to Hell.
By gaznav
#1698039
@T67M
Err, where is the evidence for this:
Roughly a 20W SE2 could have the same received power at 40miles as a 250W transponder at 130 miles or a 130W transponder at 95 miles (all approximate).
Also, ADS-B can be used as a substitute for SSR in military regulations - see MAA RAs 3222, 3223, 3228, etc...
Throughout this RA, any reference to SSR is equally applicable to Wide Area Multilateration (WAM) and Automatic Dependant Surveillance Broadcast (ADS-B).
ATS Surveillance System: Primary Surveillance Radar (PSR), Secondary Surveillance Radar (SSR), Automatic Dependant Surveillance Broadcast (ADS-B) or any comparable system (Wide Area Multilateration (WAM)) that is used to determine the position of an AS in range and azimuth. However, units who provide Radar Control Service inside CAS where only SSR, WAM or ADS-B is available should ensure local orders define procedures to cover the eventuality of an AS whose transponder is unserviceable while operating in CAS.
Automatic Dependant Surveillance Broadcast (ADS-B) and Wide Area Multilateration (WAM) are acceptable alternatives to SSR.
Now I can’t quote from the MATS or whatever the civvy controllers use, but to me it appears that ADS-B is an acceptable alternative to SSR as laid out in the Regulatory Articles (RAs). I’m also not sure where the 3-position fix for ADS-B that you mention comes from - any chance of a reference to that?
:thumright:
By gaznav
#1698041
tomshep wrote:Why doesn't it surprise me that the most expensive solution is the chosen one? With the deregulation of airways coming, the whole FIR will become a TMZ and we little people can go to Hell.
Tom, WAM and ADS-B are cheaper than legacy SSR and more spectrum friendly than legacy transponders. So for us ‘little people’ that has to be a good thing :thumright:
James Chan liked this
By James Chan
#1698108
Well I’m little yet I have no desire to go there.
Hell is available for those who ultimately choose to put themselves there?
gaznav liked this
By T67M
#1698122
gaznav wrote:Err, where is the evidence for this:
Those figures make my case perfectly, thank you Gaz. To locate a 20W ADS-B source, there need to be a minimum of 3 receivers within 40 miles of the transmitter. To locate a 250W transponder, that needs three receivers within 130 miles. Spreading that out over the UK, using 20W transmitters requires roughly ten times the number of WAM receivers to be installed. [(130/40)^2 = 10.5625, or (95/40)^2 = 5.64 for more GA-friendly devices] Who is going to pay for five to ten times more WAM receivers? Or are we (GA pilots) just going to be required to fit transponders? I know where I'll place my bets - which is why my aircraft already has an ADS-B transponder and not a low power device.
My bold:
gaznav wrote:Also, ADS-B can be used as a substitute for SSR in military regulations - see MAA RAs 3222, 3223, 3228, etc...
These quotes are slightly ambiguously worded, but one interpretation is that ADS-B alone is not sufficient and that you need both ADS-B and WAM to equal/surpass the performance of SSR. I would agree with this: without WAM, ADS-B is too easily spoofed, as we have discussed ad nauseam before, both here on Flyer and privately. For non-critical applications, ADS-B alone may be enough - e.g. to "coast" through a temporary loss of three-way WAM on a previously validated ADS-B transmitter - but ADS-B alone is not enough to validate positional information due to the trivial way in which it can be spoofed.
This quote is not equating the performance of PSR, SSR, ADS-B and WAM - it is a reminder that any system of control must cater for aircraft with no or faulty transponder, and nothing further should be read into it.
gaznav wrote:Now I can’t quote from the MATS or whatever the civvy controllers use, but to me it appears that ADS-B is an acceptable alternative to SSR as laid out in the Regulatory Articles (RAs). I’m also not sure where the 3-position fix for ADS-B that you mention comes from - any chance of a reference to that?
As explained above, ADS-B is not a suitable alternative to SSR, it is ADS-B+WAM which is suitable.
As for the 3-position fix, this is simple hyperbolic trigonometry, exactly the same as with e-LORAN, and as covered in any good secondary school mathematics text book - I would link to the excellent Wikipedia page, but I've been roasted on these forums before for daring to believe anything Wikipedia.
Hopefully it is obvious that only thing a single WAM receivers can determine is the presence of an aircraft, so I won't explain that. With two WAM receivers, you measure the time of arrival and this allows you to determine the difference in distance from each receiver to the transmitter, which puts the aircraft somewhere on a hyperbolic curve. You may have direction finding antennas which will improve the situation slightly, but in practice this doesn't make a huge difference as the angles along the hyperbolic curve are largely constant unless the transmitter is quite close to both receivers.
[Note: non-mathematicians may wish to skip the next paragraph!]
To visualise this, imagine the two WAM receivers (A and B) are due East-West of each other and 300 metres due east-west of an origin point "O" (0,0), such that A=(+300,0) and B=(-300,0) - in practice they'd be tens or hundreds of miles apart, but 600m separation makes the maths easy for this example. The signal arrives at the A exactly 1us before B, so we know the transmitter is 300m closer to A than B (taking the speed of radio waves as 3e8m/s). The transmitter could therefore be at (+150,0), (+300,+450), (+300,-450), (+600, +1006.23), (+600, -1006.23), (+1000,+1712.45), (+1000, -1712.45), or indeed anywhere else on the hyperbolic curve described by the equation y^2 = 67500*((x^2 /22500)-1) where x >= 150.
[Non-mathematicians may wish to start reading again!]
If you add a third receiver (C), you get three hyperbolic curves, each based on a pair of receivers (A-B, B-C, A-C), and thus you can locate the transmitter at the singular intersection of these three curves. If the signal at any of the three stations is lost (e.g. the aircraft moves out of range, of the signal is blocked by terrain), the transmitter can no longer be precisely located, although its position can be predicted for a while based on its observed velocity before the signal was lost, and/or raw ADS-B position reports. To be safe, however, a fourth WAM receiver is highly desirable to provide some resilience.
kanga liked this
