Mon Mar 11, 2019 9:36 am
#1680903
Aberdeen has received approval fromAirspace controlled from the Civil Aviation Authority for the use of ADS-B in the REBROS sector (pictured) of the Northern North Sea. This sign-off comes after two years of trials and means that Aberdeen becomes the first air traffic control (ATC) unit in the UK to be using ADS-B only to provide radar services.
ABS-B is a surveillance technology in which an aircraft determines its position via GPS satellite navigation and periodically broadcasts it, enabling it to be tracked by a network of remote sensors. In the North Sea environment ADS-B performs better than land-based secondary surveillance radar, as the location of the remote sensors allows aircraft to be seen at much lower altitudes – in contrast to a single land-based radar head. In many cases, helicopters can be seen setting down and lifting from the rigs, even at long range. In this respect, the enhancements for aircraft safety are significant, something that we are proud to bring to the harsh flying environment of the North Sea.
The REBROS sector, which covers around 25,000 square nautical miles of airspace to the east of Aberdeen, has an ADS-B system made up of 16 remote units; some are located on land but many are attached to offshore oil rig installations in the North Sea.
Cub
Works for uAvionix. All views expressed are mine, not necessarily those of my organisation.
