Tue Mar 05, 2019 9:04 am
#1679156
Why buy a share, get a whole one.... they are as cheap as chips!
Check condition of wood and fabric covering. Make sure drain holes on underside of
wing trailing edge are clear. Allowing water buid up will rot the wood.
Rudder post is another vulnerable area.
Check fabric, but many Jodels are now covered in more robust modern materials.
Check you fit in the seat and can see out. The seat is on the main wing spar and is not
adjustable. Different size cushions can be fitted to make more comfortable.
The A65 engine fitted to the J112 is hand swing. You need to be happy with that feature.
The handling should be crisp and precise, very different to, for example the cessnas and pipers most often used for training.
Many Jodels to have a "toe in" set up un the landing wheels. This is supposed to help tracking straight when landing, but will give excessive tyre ware on tarmac, hence the grass runway preference.
performance wise, they are all slightly different. You should expect 500fpm climb and cruise in region of 80kn but obviously engine condition and prop type will have a big bearing on that.
Operate from 500m easily.
Michael P could add a lot more I am sure. There is a Jodel yahoo group.
