By Bob Upanddown
#1663422
According to SD and the AIP, the Rigby Group airports seem to be ignoring the 8.33 requirements. Out of all their airports, only Norwich seems to have changed to 8.33, all the rest still 25kHz.
Is it legal to talk with them?????
By kanga
#1663669
Shoestring Flyer wrote:In the Oxford English Dictionary for those of us who speak proper like it is spelt with a 'c'.
In Amercanised slang that is sometimes used on 'ere it is spelt with an 's'. :wink:
from OED:
"farse (plural farses)
A vernacular paraphrase inserted into Latin liturgy.
Verb
farse (third-person singular simple present farses, present participle farsing, simple past and past participle farsed)
(transitive) To insert vernacular paraphrases into (a Latin liturgy). "
Of course, we definitely need more and unadulterated Latin, the international language of science for centuries, in aviation jargon :)
By chevvron
#1663677
from OED:
Verb
Or you could use 'farsi' script. :twisted:
kanga liked this
By Robin500
#1663703
flybymike wrote:
We have had to turn away some financially useful visiting traffic over the last year (military), in order to uphold the requirement for pilot's not to utter on 25kHz radios; quite evident is that many pilots have still been contacting us using the old, incorrect frequency.
Am I being thick?
Why would you need to turn away traffic calling on the old 25KHz frequency? If you can both hear one another what’s the problem?
Using the correct frequency/channel is the pilot’s responsibility, not ATC’s.
Am I being thick also! Went close to Pboro Sibson the other day, they've changed from 120.325 to 120.330. both are 25kz freq's, aren't they? I set the freq initially on 8.33 then toggled to 25kz and both were crystal !
#1663708
Frequency is the same, the receive filter width is now narrower. In theory, if the channels either side have been allocated to others, you would now hear others as well as who you wanted to hear when setting the 25kHz channel.
#1663717
Robin500 wrote:Am I being thick also! Went close to Pboro Sibson the other day, they've changed from 120.325 to 120.330. both are 25kz freq's, aren't they?
No, 120.325 is 25kHz, 120.330 is 8.33kHz.
What you're doing when you switch is to change the receive filter in your radio. If you select 120.325, you'll have the 25kHz filter switched in, so may be subject to interference if the adjacent 8.33 channels were to be used at the same time. By selecting 120.330 you invoke the 8.33 filter, thus filtering out any neighbouring 8.33 channels which may be in use.
T67M liked this
