By Buzzc150
#1661971
Tried it today. Seems to be unusable from a mobile device. None of the bookings are showing up. Works ok from a desktop but very messy and overly complicated. I thought they were going to release it as an app. Any news on that ?
By SamC
#1662157
its dreadful.
used to be able to book via my phone very simply and it was easy see when a plane was booked etc etc. As mentioned up thread takes several clicks to find the time someone has booked for.
unneccissary tinkering as far as I'm concerned!
until now my old app worked and now doesn't
By Cowshed
#1662167
I don’t seem to be having the issues that others are having.
On a PC, I click Sign In, then select Booking, then select Week (or Month). I can quickly see who has booked it and when the aircraft is free.
On an Android phone it is Sign In, select Booking (then you have to close an annoying popup reminder). Then by selecting the minus button in the right hand corner you change the view to weekly (or press it again to get monthly).
The ability to turn off the annoying reminders would be good, but it is not the end of the world.
When you are in the Weekly view on a phone you have to select one of the blue blocks to see who has booked the aeroplane.
In short it works for me on a PC or a phone (and in case anyone is wondering, I have nothing to do with Goboko).
Dates still need changing to a UK format though (I can’t stand the MM/DD/YYYY format).
By rikur_
#1662171
Cowshed wrote:I don’t seem to be having the issues that others are having.
I've managed to get it down to three clicks after login:
- Login
- Click 'booking'
- Select weekly view
- Select aircraft
As we've only got one aircraft in the syndicate, I'm not sure why I need to select the aircraft every time.
By Cowshed
#1662209
We've only got one aircraft too. Not sure how I've done it, but I don't need to select the aircraft each time - it successfully defaults to the only one.
By joe-fbs
#1662367
Well it works (Mac with Firefox) but so did the previous one. It's free so seems unfair to moan but just the question why on earth did someone spend their time and energy to make it more complicated and fill it with irrelevant stuff? Seems to work on iPhone with Safari but so cluttered and complex not really suitable for telephone screen. I'll try the app'. IIRC previous incarnation of the app' I deleted because it wanted me to allow access that I was not prepared to give.
App' not available.
By Johnjohn
#1663766
in your profile settings
Change the date display and save
By Johnjohn
#1663817
YOU COULD CHANGE THE DISPLAY DATE IN YOUR PROFILE SETTINGS SIMPLE JUST SAVE SETTINGS
Cowshed liked this
By rikur_
#1663839
That's helpful thanks. Also solved my problem of not having a default aircraft from the same menu.
Pretty unintuitive place to hide these settings though.
By Cowshed
#1663850
Thanks JohnJohn. Somehow the settings had already been changed for me, but I (eventually) found where there are saved for future reference - it took be a few attempts to find it even with your hint.
By Johnnyk
#1678533
Hi Everyone,
Im new to this forum so hello.
Im new to Goboko too, so I have never used the earlier version.
I must admit that I dont find it intuitive to use.
In fact I would appreciate it if anyone could tell be how to set it up so that I get an email when someone makes a booking.
