Thu Nov 15, 2018 4:39 pm
#1651272
...Unless Uavionix do what PAW do tap into the OGN, which presumably would cost them nothing in terms of licenses.
cockney steve wrote:AIUI, universal adoption of ADSB, is the perfect way to ensure the whole ATC system collapses through overload. Didn't the Dutch burn their fingers badly with this ideology?.......
The Authorities keep banging on about ADSB for all air traffic,- the Dutch proved it's the road to chaos.
ls8pilot wrote:PaulB wrote:Why can’t all devices “squit” ADS-B out then (for example) FLARM could do it’s clever (and probably proprietary) stuff that it does for loads of gliders using the same thermal and other devices could do stuff for their own populations, but in essence everyone would be able to see everyone else. Given that we now have (if I read it correctly) a drone that “squits” and can receive them, there’s an even bigger incentive to use ADS-B.
The manner in which Flarm works relies on the transmitted information containing three dimensional velocity vectors, as well as height and position.
ADSB-Out protocol (AFAIK) just has altitude and position, so you cant just get Flarm devices to use ADSB information, you would need a whole different (more powerful) receiving device and set of algorithms. Given the large Flarm installed base in Europe there is no likelihood they will abandon their existing protocols and user base. The big advantage of Flarm is backward compatibility, so a Flarm device installed 10 years ago still interacts with the latest kit.
A better solution would be for either an upgraded Flarm device that does ADSB-In/Out alongside Flarm, or better an ADSB/In-out device that will support the back-end protocol used between Flam and Traffic displays.
I do agree that ultimately, while Flarm will remain, the existing Flarm users will & should use ADSB as well. However unless ADSB is mandated then you're looking at several years before this is the case. It's take more than 10 years for the Flarm user base to reach it's current levels.
ls8pilot wrote:ADSB-Out protocol (AFAIK) just has altitude and position, so you cant just get Flarm devices to use ADSB information, you would need a whole different (more powerful) receiving device and set of algorithms.
riverrock wrote:ls8pilot wrote:ADSB-Out protocol (AFAIK) just has altitude and position, so you cant just get Flarm devices to use ADSB information, you would need a whole different (more powerful) receiving device and set of algorithms.
ADS-B also outputs velocity, heading, vertical speed. See https://mode-s.org/decode/adsb/airborne-velocity.html
Tim Dawson wrote:There’s nothing Flarm does that couldn’t be done with the data broadcast over adsb.
