Re: Helicopter down, Leicester City FC
PostPosted:Thu Dec 06, 2018 2:33 pm
https://assets.publishing.service.gov.u ... vhpeaVaKVw
"The evidence gathered to date shows that the loss of control of the helicopter resulted
from the tail rotor actuator control shaft becoming disconnected from the actuator lever
mechanism. Disconnection of the control shaft from the lever prevented the feedback
mechanism for the tail rotor actuator from operating and the tail rotor actuator from
responding to yaw control inputs. Loss of the feedback mechanism rendered the yaw
stops ineffective, allowing the tail rotor actuator to continue changing the pitch of the
tail rotor blades until they reached the physical limit of their travel. This resulted in an
uncontrollable right yaw.
Sufficient force and torque had been applied to the castellated nut on the actuator end of
the control shaft to friction weld it to the pin carrier and to shear the installed split pin. The
observed condition of the duplex bearing and the increased torque load on the castellated
nut that remained on the spider end of the shaft is consistent with rotation of the tail rotor
actuator control shaft. Whilst the shaft was rotating and a yaw control input was applied, the
shaft “unscrewed” from the nut, disconnecting the shaft from the actuator lever mechanism,
and causing the nut to become welded to the pin carrier. "
