Mon Sep 10, 2018 4:55 pm
#1637185
HASELL checks FD? Otherwise agree.
The way you're flying this, I see in a great many PPLs I fly with as an instructor, and usually ends up with the same results.
Firstly - if the engine has done something odd, sweep the cockpit looking for potential to clear / restart. With practice that should take seconds and should be your second instinct after the first one of aggressively trimming best glide and pointing into a safe area.
Second, whatever happens, the aeroplane's drag characteristics won't be the same as they were with the throttle at idle. Probably worse, maybe much worse - so anything based upon assuming you know the glide behaviour is going to end in tears.
I would look for fields MUCH closer - stretching the glide will also end in tears. Position yourself around downwind/base (circuit direction doesn't matter, nor do precise heights). Once you have the field, re-trim to your minimum approach speed. And then use a turn to adjust to your aiming point, which typically is around a third of the way into your "runway". Widen the turn if the aiming point is going down in your field of view, tighten it if it's going up. Roll wings level and dump the flaps quite low when you can definitely make the target - the flaps should then bring the touchdown point a bit closer and set up a nice landing.
1200ft is also far too low to start practicing stuff like this. Like Lobstaboy says, try nearer 3000 (ditto, as FD says, for stalls) then as you get good, reduce the start heights.
And lastly, the man who tries to teach himself how to fly has an idiot for an instructor. Go and spend quality time with an experienced instructor who can demonstrate and explain this vastly better than any of us can in the format this bulletin board permits us. With 42 hours you're a beginner, and need to remember that. All this stooging around low level in an aeroplane with an uncertified engine, over forest, is also not the cleverest thing I've ever seen.
