Fri Sep 21, 2018 10:18 pm
#1639627
You're asking a lot there, but, before this thread is locked I can offer:
At the moment, you aren't supposed to use Skyecho out if you have a Mode S transponder, but I would. That would help others but there aren't many GA out there to appreciate the effort.
As you say, you will see lots more with Pilotaware, but only Pilotaware users will see your GPS position and baro height, the rest would be up to existing systems on the aircraft which are likely to be Mode C, or even Mode S.
So, you have Pilotaware and see most stuff. You can add Skyecho which would add ADS-B 'Out' to the 'In' you already have, so the those GA that can see ADS-B 'In' (but not Modes C/S and OGN-R) can see you but it doesn't increase your SA.
I'm not sure that's what you want, but that's what it is (IMO?)
[edit]IMO the natural way to do ADS-B Out is to upgrade your transponder (if you have one, our share has an S), we would have one already if Garmin didn't demand the cost of a transponder to upgrade the 'Mode S/ES ready' Garmin 330 to ES, after we paid extra to have it 'ES ready'! {Nurse!, more meds!}[/edit]
