Hi Gaz,
gaznav wrote:
PS. Overnight afterthought. Just to add that OFCOM and the CAA have signed up to allowing low power portable ADS-B
Can you post a link to this ?
Hi Lee
It’s CAP1391 - page 32 Table 2 “ADS-B Classes” where it discusses a Class A0 as “
Lower transmit power and less sensitive receiver than Class A1”. Obviously portable Electronic Conspicuity (EC) and Transmitting Portable Electronic Device (T-PED) is mentioned throughout. Further there is the Declaration of Capability and Conformance (DoCC) Form SRG1757 - this is sent to the CAA for them to
approve the portable ADS-B T-PED even if Class A0. The SkyEcho has a valid DoCC which is the T-PED’s approval - seen here:
Then, when you buy one you have two choices - you can put it on your extant OFCOM Radio Licence for your aircraft free of charge, or, if like me, you want to use your SkyEcho in various aircraft then you pay Radio Licencing . They treat it as a “Transportable Radio” and charge £15 for 3 years.
So there you have your answer - low power ADS-B is acceptable to the CAA and approved, plus OFCOM have also approved by licensing the device for use. There are no ‘strings attached’ to the approval apart from, at present (and hopefully not for long), you cannot use the SkyEcho with a functioning Mode S transponder. As both my aircraft do not have one then for me it is the best solution - sadly I won’t see your bit of kit transmitting but at least it will see me.
Finally, Marvin beat me to it. There is, I would suggest, no guarantee that PAW would not be booted off of 869.5MHz as it is also congested and used for a range of other uses - asset tracking systems, meter readers, industrial telemetry/telecommand equipment, data loggers, in-building environmental monitoring/control systems, social alarms, high-end security/fire alarms, and vehicle data up/download. Especially if PAW gets the saturation of the GA market that you hope for - lots of aircraft-borne PAWs in line of sight of lots of other ground based systems
may in future cause issues to these ground based users. I believe the whole idea of the 869 so-called “free use” predicated on the fact that it was for short range line of sight work
on the ground that is unlikely to interfere with each other? Whilst not a problem right now with an estimated 500-1,000 regular users, might it be that any issues
may not have manifested themselves just like the 1090 discussion? I would also be so bold that getting the DoCC for use of equipment on a band reserved for aviation (1090) might actually be a safer bet? But that is entirely based on a hunch and that is all
Best
Gaz
