GolfHotel wrote:Dave W wrote:If you have your RV-7 cleared by the LAA for flight in IMC, I don't think that clearance is valid outside the UK though, is it?
As I understand it and have been told, on here so it must be right. Yes it is valid outside the UK. I suppose they could restrict you to VMC if they so choose.
There are a lot of pitfalls here, putting aside whether the aircraft itself is legal to fly abroad - something I just do not believe as a blanket statement without further qualification.
1) if you are operating it abroad on a UK National PPL - i.e. not converted to, or issued alongside, an EASA PPL - you will need a current full UK IR attached to it.
2) If you are operating it abroad on an EASA PPL, you will need to have a full IR attached to that.
3) The UK is almost unique in having its casual approach to IFR - unless you are under an ATC clearance, VFR/IFR status is a matter of being in your head and making sure you comply with IFR when under IFR. Things are not so straightforward (or actually more straightforward, depending on how you view things) in other states i.e.:
- you will almost certainly have to file an IFR flight plan. You might get lucky and be able to request a pop-up clearance for a quick IFR transit of CAS, but the default assumption will be that you want to be 'in the system'. This means you could get vectored anywhere. Filing the plan will require validation through Eurocontrol, which means declaring your equipment. Some of this HAS to be certified, as PBN operations are predicated on total system performance in all categories. PilotAware driving your own Android EFIS app on a £50 Hudl will not cut the mustard - Flight Manual Supplements against an STC or other equipment approval are required.
- if you are operating under an EASA licence you must have the IR to fly under IFR at all, VMC/IMC doesn't come into it. This in the UK is easily achieved with the IR(R), but not elsewhere. There is no opportunity to 'restrict you to VMC' - ATC won't know, and in some states you -will- be in CAS, and expected to remain so or cancel IFR.
- Under the CAA's attempts to align the ANO with SERA and EASA, the above point might also apply to UK National PPLs as well.
Don't get me wrong - the more IFR capable aircraft there are the better whatever their CoA/Permit status - but there is a lot to consider if you operate on the margins of the norm.
