Thu Jan 18, 2018 2:41 pm
#1584963
Rob P wrote:Which one specifically? How does the mount mount to the panel?
Screws/bolts normally, but suction cups are available.
CaptChaos wrote:I tend to use RAM Xmount. You can fit the ball unit either permanently or via suction mount and Xmount will grab various sizes of tablet. You can angle to minimise glare and still access connectors.
TheKentishFledgling wrote: ... and see the solution he employs for mounting his tablet. Looks really slick, and emergency "loss of power" option is cool too
madmaveric wrote:.... as long as you have a phone signal.
Flyin'Dutch' wrote:I would go for the classic T layout, the Dynon in the middle, top left ASI top right ALT.
The engine monitor should do its thing quietly and no doubt raise its 'voice* when necessary. So that can go to the RHS.
Ipad to the Engine Monitoring place.
Switches over the circuit breakers you of the way
Radios where the switches are.
G Meter and VSI under ALT and ASI.
Shoestring Flyer wrote:... is a 'Flypad' mount
