gaznav wrote:I’ve never heard of an injury from flying in a HIRTA but there are plenty of industrial injuries with folks working in the telecomms industry.
An engineer replaced a damaged feed horn of a microwave antenna, a 15-meter dish at an Earth Station of a television network, using a cherry picker. After finishing, he sent his technician to power up the transmitter, and attempted to lower the cherry picker down. The engine failed and the engineer was stuck next to the antenna, outside of its main lobe but well within the first sidelobe. The technician, unaware that the engineer was still close to the antenna, powered it up. The engineer was exposed to an intense microwave field for about three minutes, until the error was realized. There were no immediate symptoms; the next morning the engineer detected blood and solid matter in his urine, and visited a doctor, who found blood in his stool and massive bowel lesions. The engineer's medical problems lasted for many years.
Source: Microwave & Wireless Communications Technology, by Joseph J Carr (1996)
The sidelobes’ power can be 100s/1000s times lower power than the main lobe on a satellite parabolic antennna.
ianfallon wrote:Does that military chart indicate any height info for those semi circles ?
nallen wrote:The Croughton folk told the gliding club years back that they don't really care about people flying over, but if you insist on orbiting overhead, remember that it's your gonads being irradiated. I think they were joking... (I often use -- and did today -- 27LH, skirting through Croughton to do so; same if using 33.)
gaznav wrote:Aerotech Flyer wrote:Is the Sea Harrier still in the garden of the big house on that route from Croughton to Hinton?
Sadly, not seen in quite a while. It was ZD582 and on the Rowler Manor estate. The owner has quite a few farm buildings so it may be now inside?
TouringTuggy wrote:..
A couple of guys based there came over for some gliding, and confirmed that they only receive at Croughton - so with nothing being transmitted it’s no issue flying through. Just as well as have been doing so for years...
chevvron wrote:pullup wrote:You need to compare your aircrafts HIRTA Rating with the published HIRTA Ratings in the RAF En Route Supplement (also known as the Red book).
Don’t have a HIRTA rating....thought so...no restriction then.
Least that’s the way it was....Much ado about nothing.
The Red Book (also known as BINA) is regrettably quite expensive. A much more detailed listing of HIRTAs is contained in the AIP (MIL) in the Low Flying section which is equally innaccesible to civil pilots.
Paul_Sengupta wrote:I thought we'd come to the forum decision a while back that it was best avoided if you have electronically armed bombs on board...SteveX wrote:testing fuel for water religiously (like when the aircraft already flew and it hasnt been refuelled)
It's more likely to be leaky tank caps, so best checked after rainfall.
Longfinal wrote:chevvron wrote:pullup wrote:You need to compare your aircrafts HIRTA Rating with the published HIRTA Ratings in the RAF En Route Supplement (also known as the Red book).
The AIP(Mil) is available to all here https://www.aidu.mod.uk/aip/aipVolumes.html
