Page 1 of 2
SkyDemon virtual radar issue?
PostPosted:Sat Nov 25, 2017 5:36 pm
by A le Ron
Since my last SkyDemon update today, the virtual radar in planning mode plots random altitudes, e.g. Sherburn to Full Sutton at ground level only (despite 5000' being set), and Sherburn to Sandtoft at 5000' only, with no climb or descent. Am I the only experiencing this?
Re: SkyDemon virtual radar gone haywire
PostPosted:Sat Nov 25, 2017 5:49 pm
by neilmurg
anything on the SD forum? which device are you running, which version of SD, operating system.
My Galaxy Tab S2 8", Android 6.01, SD 3.8.5.25814 works fine
PostPosted:Sat Nov 25, 2017 6:08 pm
by flybymike
3.8.589 working fine for me on iPad Pro.
PostPosted:Sat Nov 25, 2017 6:10 pm
by Tim Dawson
Check Flight Details for an explanation. Maybe strong wind is affecting the modelling of your flight. Try a different aircraft profile.
PostPosted:Sat Nov 25, 2017 6:30 pm
by A le Ron
Version 3.8.5.89 running on an iPad 3.
The problem occurs with some but not all aircraft profiles, and some but not all route altitudes. Using my twin comanche profile (which has not changed since the previous version) it won't model short routes at 5000' but will model them at lower ceilings, but will allow me retrospectively to raise the ceiling by dragging the line up to altitude where the modelling has failed. Using the profile 'simple aircraft ' it works first time. Bizarre.
PostPosted:Sat Nov 25, 2017 6:34 pm
by Tim Dawson
I didn’t think we had made a change to that flight modelling recently but if you find the problem persists (ie it’s not current wind conditions doing it) please do send us a route which fails to model and we can look into it for you.
PostPosted:Sat Nov 25, 2017 6:42 pm
by A le Ron
Problem persisted when future times with no wind info are set
PostPosted:Sat Nov 25, 2017 7:15 pm
by flybymike
Second route possibly set using Cardemon?
PostPosted:Sat Nov 25, 2017 7:30 pm
by A le Ron
flybymike wrote:Second route possibly set using Cardemon?
MoleDemon..
PostPosted:Sat Nov 25, 2017 7:32 pm
by flybymike
PostPosted:Sat Nov 25, 2017 7:35 pm
by neaton
The new SkyDemon AI module has analysed your recent flights and decided you're better off taxying?
PostPosted:Sat Nov 25, 2017 7:40 pm
by johnm
Does flight details tell you of a performance issue, it’s fine for me unless I give it an impossible task
PostPosted:Sat Nov 25, 2017 7:51 pm
by A le Ron
No, it doesn't. And the same routes/aircraft profile have modelled fine previously. I'm just going to try the same tasks on my PC with an older version of SD. I will also try them on Android.
PostPosted:Sat Nov 25, 2017 8:12 pm
by johnm
I hesitate to say this but have you done a hard reset on the iPad?
Re: SkyDemon virtual radar issue?
PostPosted:Sat Nov 25, 2017 9:15 pm
by A le Ron
Like putting my fist through it?
