Tue Nov 21, 2017 6:16 pm
#1573039
Rikur,
If you make sure your PAW is running the most recent software you can connect to SD via UDP rather than TCP (just select ‘PilotAware’ rather than ‘Flarm’ in SkyDemon / Settings / Connectivity Options). This was added at the request of SD as it can prove more reliable. When you ‘Go Flying’ you select ‘Use PilotAware’ and it automatically uses the UDP WiFi Connection. Always worth a try for anyone having ‘WiFi’ problems.
Regards
Regards
Paul_Sengupta liked this
