GonzoEGLL wrote:Full Metal Jackass wrote:
That check list could get me a blocking at certain airports I fly from - in particular where heavy metal is landing. If you switch on your transponder to ALT whilst parallel to the runway doing your run-up checks and a TCAS equipped jet is landing, you will cause a TCAS alert to be given which means paperwork....
For that reason they demand, especially if CAT is on final, that the transponder is only switched ON / ALT when you line up on the runway.
I'm not sure this is correct.
TCAS II inhibits any RAs below 1000ft AGL, 'Descend' RAs below 1100ft, and 'Increase Descent Rate' RAs below 1550ft. It should also filter out any transponder returns that are at 0ft AGL.
Well obviously something went wrong that day. I was parallel to the Runway at EDDG having just completed my engine checks and had switched on my transponder, was switched over to Tower where an incoming pilot was talking about 'receiving an alert' and the tower then asked me if I had mine on - which obviously I did and told him so.
His response was that I should
never turn on my transponder until I'm lined up and cleared for takeoff because it gives issues for other aircraft and since then, I turn on my transponder just before synching the DG.
20.000v in his arms but the bulb inside his head still doesn't light up........
