Sun Sep 17, 2017 11:52 pm
#1559342
We have to teach soft field landings.
In the 150/152 I teach 20 degree flaps for this procedure as a soft field landing is also a test of the surface and you may want to go around.
Trying to take off with 40 degrees flaps in a 172 caused a crash, youtube: "last minutes Cessna". HS TVS.
The pilot and I had many arguments... This crash caused a lot of trouble for all of us who fly in Thailand.
This chap also flew as an instructor but had no rating anywhere... He and a student were 150lbs over the gross weight limit for the Cessna 152.
He never did his checks.
If you do "controls full and free and in the correct sense", and look at them to confirm before takeoff you can not miss it if the flaps are down.
Checks are the answer. Using the checklist is one thing, but belts and braces, if you learn the ATA checks you can do a memory recital to confirm everything has been done.
Lined up at Bang Phra, wires ahead, the instructor selected 10 degrees flaps in the Cessna 150. I put them back up, zero flaps, and told him to read the POH.
Once near Pulborough I tried to get G AYRO (150) off a soft field in which it had forced landed.
Selected 10 degrees, and at my go/no go decision point the nosewheel was stuck to the mud, and the airspeed was too low, 35KIAS, so I closed the throttle.
With flaps selected there is more weight on the nosewheel, and less effect from the elevator. Full up it's probably stalled due to the angle of the airflow from the depressed flaps.
Try number 2 was with zero flaps, and at my decision point the ASI read 45KIAS with the nosewheel clear of the mud... I can fly.
Three seconds on the flap lever and ten degrees went on without me looking at it and the aeroplane popped off the dirt.
Once I eavesdropped on a PPL flight test. Due to the examiner's weight the candidate found the aeroplane to be 45lbs over weight. (152).
The examiner said that it was alright and off they went.
The Cessna 150/152 are maligned by many skygods, and yes you can get away with many things, flying and landing with less than ideal skill.
But skill can still be developed by a good instructor using this aeroplane. If you learn to fly it well it's not so difficult to transition.
It did not take me long to transition to a tailwheel aeroplane after learning in the 150... Landings were the same, just keep the tailwheel aeroplane straight.
MichaelP
Wandering the World
