Dusty_B wrote:12 seconds per minute? Break your scan cycle down to 15 second segments, and you're giving yourself just 3 seconds to refocus on the instrument panel, adapt to the different light levels, saccade across a selection of instruments, and assimilate the information presented. 80% is very demanding amount of time!
I accept that you may be correct, I was assessing this subjectively, I have never tried to measure it, have you?
12 seconds EVERY minute still sounds like a lot to me.
So what do we need to check every minute? Not much, I would suggest.
If I am flying S&L I am going to check where I am in relation to my magenta line every 2 or three minutes. That check will take less than a second. Occasionally, if there is bad weather ahead or I have some other decision to make it may take longer.
I will check Ts & Ps maybe once every five or ten minutes, again a glance, again less than a second.
I am going to check altitude more frequently, lets say once per minute and compass course, similar, I think that I can do both of those in a second.
Landing, on short final, is different, I am keeping a closer watch on the speed. Aerobatics is different I am keeping a closer watch on heights. But in both cases frequent sub-second glances are the order of the day.
I accept that I may be over-estimating the time that I am head up, but I am still confident that I exceed 80% of my time. Maybe I am not spending enough time monitoring instruments
