Sun May 28, 2017 4:35 pm
#1537421
I have had a long and sometimes acrimonious, post going on the technical forum re ASI error and approach speed in my D117. Please feel free to peruse.
The characteristics of the wing and having no flaps or airbrake can lead to an un-stalled but very rapid descent if speed decays below 40 knots indicated ( on mine). You need to have flared and be just above the grass by this time.
The actual stall I take to be just under 34 knots, as that is the indicated speed at the (just beginning) of lift off.
I use 65 knots turning off base, slowing to 55 on final and then an absolute minimum of 43 on ultra short final.
Below this mine has insufficient energy to flare even with smoothly applied max back stick.
Actually that's not accurate - it rotates nose up, but still keeps the same path through the air and ' carrier lands-on' quite firmly.
Having a puff of engine on to the end is vital ( for me) as it limits the sink, gives me a means of descending slightly more by taking it off as well as stretching the approach by putting a bit more on, and finally let's me get a very positive 'landing on' and "stick on" when I close the throttle after flaring.
All very necessary at our short, tricky, strip.
The ' problem' is, its easy to end up well on the wrong side of the drag curve by using more throttle than that - dangerous.
For the record, mine doesn't drop a wing in up -to a max rate slip - thank goodness or I would go around a lot.
Also visibility is superb on approach - if it isn't, you are at a lethal angle of attack.
Last thing - mine had a little automatic flip up pitot cover. I've just taken it off and the airspeed over-read error has vanished.
I'm assuming turbulence from the ' flap' part was the problem.
Position error at high angles of attack is unknown, but assumed to be quite high, as per the translated pilots notes.
I came from the usual C172/ PA28 world and it's very different, there is a section of the flight envelope that you can get into that is simply not available to those aircraft.
It's a bit more like the energy management requirements of landing in gliders- sort of.
For what it's worth, it's 10 times more fun at half the price, but, it makes me sweat a bit sometimes. Usually going into a new strip on a cross-windy, bumpy day. But that's why we do it, isn't it?
