#1531538
Dave W wrote::lol: :clap:
Thing is... how could you set QFE for Mountain Home AFB. elevation 2,996ft?
The pressure selection doesn't go that low. At ISA, you'd need to be able to set 913hPa (26.96 inHg) in the subscale Kollsman window. A typical altimeter won't go that low.
Don't need to; for low level displays they normally use a radalt.
By nallen
#1531541
<continuing the thread drift on altimeter setting>
I don't know if this is the altimeter fitted to that doomed F16, but the majestic omniscience of the internet produces the spec for a solid state device: http://www.kellstromdefense.com/PDF/Tech_Sheets/F-16-Solid-State-Barometric-Altimeter.pdf. 950-1048 is its operating pressure range …
#1531555
neaton wrote:
chevvron wrote:Don't need to; for low level displays they normally use a radalt.
Presumably a radalt isn't a lot of use if you're inverted?
Nor is a barometric altimeter if you're low level; it has to be done on eyeball.
#1531556
A radalt will only give you height above the bit of terrain you are over, not the display datum which is what you need. None of the steam driven aeroplanes I am use to at displays would have one. I made a 'too low' call to one at an air display and he said he was at 'xxxft radalt'. We knew very well he didn't have one!
By townleyc
#1531568
nallen wrote:<continuing the thread drift on altimeter setting>
Wouldn't that restrict you on an ISO day to 1700 AMSL?
KE
