#1519874
As I understand it (using the word understand in its loosest sense) post April 2018 a pilot must have an EASA licence (LAPL or PPL) to fly an EASA aircraft and may also fly (LAA) permit aeroplanes. NPPL may only be used on LAA permit types.
Those of us with an NPPL and an EASA licence have been able to use hours flown towards revalidating either licence.
In a post 2018 world will it be possible to revalidate by experience an NPPL with hours flown in EASA aircraft? Or is it going to be necessary to get some time in an LAA permit aeroplane to keep the NPPL alive?
#1519919
We agreed this would be permissible at an early stage during EASA transition with the CAA. Information is contained in LAA Technical Leaflet 2.09, which I edit.
http://www.lightaircraftassociation.co. ... rcraft.pdf
Training towards EASA and non-EASA licences, ratings, or certificates is permissible, and flight time conducted in LAA aircraft counts towards those required under EASA towards the issue, renewal, or revalidation of a licence, rating, or certificate.
Cookie
Ian Melville liked this
#1519962
Yes, it will be possible to continue to revalidate class ratings in a NPPL with hours flown in EASA aircraft beyond April 2018.
Really? Given that neither the NPPL nor UK PPL will be valid for flying anything except non-EASA aircraft after 7 Apr 2018, how do you draw that conclusion, Cookie?
#1520006
Ian Melville wrote: Like #neilld, I would like 3 axis micro hours to count as well, but not holding my breath.
It really is time this was sorted. This issue was raised in the Red Tape Challenge and the CAA (bless them) have sorted it for UK PPL holders.
I have raised this with the CAA (as EASA associates) on a number of occasions, most recently at Sywell last year when I was directed by the CAA rep (can't remember his name but he does the presentations on the new ANO) to Jon Cooke who was going to raise it at a forthcoming visit to Cologne, since then nothing.
Like Ian, I'm not holding my breath, in fact I probably wont live long enough to see it happen.
As we all know, EASA are a complete waste of (air)space.
#1520016
Ian Melville wrote:That was my assumption as well. I am planning to run a NPPL(SSEA and M) and a EASA LAPL in tandem. So I want whatever I fly to count accross the divide. Like #neilld, I would like 3 axis micro hours to count as well, but not holding my breath.
Ditto.
#1520022
The issue sits with implementation of proposals within EASA NPA 2014-29 and not within the EASA Rule Making Task I am involved with. During the ANO Review, the CAA elected to implement crediting of three-axis experience towards class rating revalidation within ANO 2016 in advance of the amended EASA regulation following comments from myself and other stakeholders. However, the question has been asked of EASA and I understand the associated CRD is due at the end of March.
The national licence itself would be valid for flying all aeroplanes within the SSEA class were it not for the overarching EASA regulation which prevents the pilot from exercising those PIC privileges in EASA aeroplanes beyond 08th April 2018. In any case, the 'one hour with an instructor' is conducted with the licence holder as PUT, and the instructor as PIC so it would only be the instructor who would require an EASA licence in that flight.
When close to the original expiry of this derogation in April 2015, this issue was discussed with the CAA. The problem was then shifted to April 2018 with extension of the existing derogation hence the same issue being raised again now. An EASA aeroplane 2,000kg and under in the SEP class actually falls within the licence holders' SSEA class rating, it's just that European regulation prevents that pilot from exercising PIC privileges!
And while we are on, it's about time that holders of full EASA PPLs were allowed to fly with reduced privileges using an LAPL medical, without the completely unnecessary additional expense of paying for a separate LAPL licence.
That's very much work in progress, and also within NPA 2014-29(A) the CRD for which is belatedly due end of March. LAA submitted a comment (#734) in response to this NPA back in May 2015 to that effect:
The LAA fully support use of the PPL(A) to provide LAPL(A) privileges. A common cause for pilots wishing to exercise LAPL privileges whilst holding a PPL might be a temporary downgrade of their medical certificate from Class 2 medical to LAPL medical. This might be due to a medical condition or through choice by wishing to take advantage of the extended medical validity of a LAPL medical.
This amendment does not address the above issue, where a PPL(A) holder would still have to hold a Class 2 medical in accordance with Part-MED even when exercising LAPL privileges under the proposed amendment to FCL.205.A. We have successfully used a system in the UK for a number of years through an exemption issued by the UK CAA (ORS4 No.995) where a UK national PPL holder, with valid SEP class rating, may exercise the privileges of a National PPL (NPPL) with a valid NPPL Medical Declaration.
In accordance with the above, where a PPL(A) holds a valid LAPL(A) medical, it is suggested the regulations are amended to reflect licence privileges appropriate to the LAPL medical held (FCL.105.A).
It is felt that the current wording of this FCL.205.A amendment may cause confusion about pilot privileges and recency, leading to pilots operating illegally due to not meet the relevant recency and medical criteria.
Cookie
